Originally published at: Has FMCSA's Decade-Old Chameleon Carrier System Been Running on Autopilot? - FreightWaves
When a November 2025 draft memo from the Department of Transportation surfaced promising a groundbreaking “data-driven severity matrix” to catch chameleon carriers, it raised uncomfortable questions about ARCHI (Application Review and Chameleon Investigation), built with $3.5 million in congressional funding in 2012-2013. Is this bureaucratic amnesia, rebranding of an underperforming system, or evidence that FMCSA’s chameleon detection infrastructure has been quietly abandoned?
The Great Disconnect: A Billion-Dollar Regulator and an Industry Left Unpoliced
America’s motor carrier industry is unraveling under a problem Washington refuses to confront: the widening gap between how trucking actually operates in 2025 and how the U.S. Department of Transportation and the Federal Motor Carrier Safety Administration regulate it.
FMCSA is neither small nor underfunded. It operates with an annual budget of roughly $945 million and a workforce of more than 1,450 employees. Yet despite these resources, the agency has become largely reactive—issuing DOT numbers, collecting data, and responding after disasters rather than preventing them.
The evidence is everywhere. There are now 1.16 million for-hire motor carriers and more than 100,000 freight brokers registered with DOT. Truck capacity has surged even as freight rates collapse. SONAR data shows the U.S. tractor population accelerating past 2 million units, while DOT Census filings reveal a sharp rise in new, often foreign-linked carriers after 2018.
Meanwhile, enforcement tells a different story than official assurances. ICE and state roadside operations routinely find 20–30% of stopped trucks operated by drivers with fraudulent, expired, or non-domiciled credentials. Cargo theft is now industrialized. Double-brokering is common. ELD manipulation persists. Fatal truck-involved crashes are up roughly 40% compared to a decade ago.
Even more troubling is institutional amnesia. A leaked 2025 DOT memo promotes a “new” data-driven system to identify chameleon carriers—companies that shut down and reappear under new identities to evade enforcement. But Congress already funded this solution in 2012, allocating $3.5 million to build ARCHI, a system FMCSA said was operational by 2016.
Then ARCHI vanished from public view.
Is it still running? If so, where are the results? If not, why did it stop? Why is DOT describing decade-old capabilities as breakthroughs?
This is not a technology failure. It is an enforcement failure. FMCSA already has the authority, the data, the staffing, and nearly $1 billion a year. What it lacks is accountability.
As a result, private industry has filled the void. Shippers now rely on tools like DAT Alias Search and Genlogs to identify fraud—functions that should occur at federal registration. Meanwhile, compliant American carriers are crushed by operators exploiting loopholes FMCSA refuses to close.
If trucking is the bloodstream of the U.S. economy, DOT is allowing contaminated blood to circulate. The National Security Strategy links supply chains to national security. But resilience is impossible when the freight system is porous, unverified, and effectively self-policed.
With $945 million, 1,450 employees, and more than a decade of warnings, continued inaction is no longer defensible. The disconnect is measurable, dangerous, and entirely preventable.
They need to raise the barrier of entry signifcantly. It’s way too easy to get in the business so they are overwhelmed with trying to manage. So stop them at the door.
