Ghost Agents running America's trucking legal infrastructure
Originally published at: Ghost Agents running America's trucking legal infrastructure - FreightWaves
89 agents control process agent relationships for 1.67 million American carriers, several of those agents cannot be verified as legally incorporated entities in any state, In 2019, the FMCSA said enforcement personnel were reporting an inability to complete service of process when the agent on file simply refused to answer.
The System You Can’t Sue: How U.S. Trucking Eliminated Accountability
America’s trucking system doesn’t just fail to prevent danger—it often fails to deliver accountability after the damage is done.
Start with a simple premise: if a truck kills someone, the victim’s family should be able to find the company responsible and bring a case. Federal rules were built to ensure exactly that. Every interstate carrier must file a BOC-3, designating a process agent in every state so legal papers can be served. In theory, this guarantees access to justice.
In practice, it doesn’t.
Today, that system has been hollowed out. A handful of process agents—some legitimate, others little more than mail drops—control access points for more than a million transportation companies. Some operate from shared addresses or post office boxes. Some cannot be verified as real businesses. When lawsuits are filed, service fails. No response. No appearance. No case.
30 N Gould St, Sheridan WY or 3377 California Ave, Signal Hill CA come to mind.
The mechanism meant to ensure accountability has become a shield against it.
This breakdown doesn’t exist in isolation. It sits atop a broader system that prioritizes throughput over verification. The Federal Motor Carrier Safety Administration grants operating authority based largely on submitted paperwork, yet most carriers operate without a formal safety rating. Identity can shift across entities. Companies dissolve and reform under new numbers. What appears compliant on paper may not exist in any meaningful operational sense.
And yet freight keeps moving.
Every load is selected, assigned, and moved through a chain of decisions made in this environment. Large shippers and brokers depend on it. Low rates depend on it. Speed depends on it. The system does not stop when risk is identified—it adapts to keep goods flowing.
The result is a closed loop: a carrier enters easily, operates under minimal verification, and if something goes wrong, may not be reachable at all. Enforcement actions stall. Civil litigation collapses before it begins. The public is left bearing the cost.
This is not merely regulatory failure. It is structural design. Barriers to entry are low; barriers to accountability are high. The incentives are clear, and they are misaligned with public safety.
Fixing this does not require reinventing the system. It requires enforcing the one promise it was supposed to keep: that when harm occurs, the responsible party can be found.
Until then, we are left with a system where companies can operate on America’s highways—and, in too many cases, cannot be held to account afterward.
That is not oversight.
That is organized absence.
